Discuss New oven plug or hardwire? in the Electrical Forum area at ElectriciansForums.net
Dee
Hi
Can i put a 13amp plug on this oven and plug into a normal socket?
Thanks in advance
Electrical installationThis product requires hardwiring to a 13 Amp fuse and should be installed by a qualified installer, such as one of our Team Knowhow experts.Power supply13 Amp (Requires hardwiring to a fused spur)
Blissof89 - I guess your opinion is correct.
The regs say you must follow manufacturer instructions, no? So there's no choice really.
regs say you should take note of MI. if sensible follow if
大量的鸚鵡
then ignore.
Telectrix - ignore? Can't you see that opening a can of worms? If a manufacturer from China can't make a manual would you be happy about your neighbour in the flat downstairs installing their products?
Also it might affect your insurance premium if sh*t happened.
Hi Dee - although the plug and socket is rated 13A same as the fused connection unit, the fcu will likely take the load better over time. Out of interest can I ask make and model of oven please?
Cover your a**e and install an FCU. Let's say the oven was found to be the cause of a fire, the loss assessor's main objective will be to find escape clauses so the insurance company he/she represents (that happily take your premium each year), don't have to cough up. If you put a BS1363 plugtop on it, you have contravened Reg. 510.3 and it may come back and bite you.
Not the MI then?
I guess this is a non issue, unless the instructions for country X specifically stipulate a hard wired connection, where there is no such thing in country X and their wiring regs have a clause equivalent to our 510.3. Does this scenario exist? Most instruction booklets nowadays feature a few pages for a dozen or more countries.
Reply to New oven plug or hardwire? in the Electrical Forum area at ElectriciansForums.net
