Electrical2Go - Online Electrical Supplier
Discuss New PV System performance in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
K
kevhky
Hi, first off im Kev, hello to everyone to the forum
Just two weeks ago had a pv system installed but im not reaching my peak as so i think my system is as follows
14 x REC 240w panels total 3.36kw
1 x Powerone aurora unu 3.6kw inverter
South facing
roof angle 30 degrees
over the previous two weeks we have had some particular good sunshine days (well only a couple) but my highest peak since install is only 2.77kw
on these particular sunshine days it was midday and the sun was directly shining straight at me roof
I though on days like this i should be achieving maximum peak of at least 3.3kw - 3.4kw
Any thoughts on this or am i expecting too much
Thanks in advance
Kev
Aico 3000
F
FB.
  • #2
Recently my panels have only been running at about three-quarters of their maximum potential (2.7kW being produced with 3.7kW of panels and the same 3.6kW inverter as you).
Hot weather drops the output.
There also hasn't been much of a breeze to cool the panels recently.
....and round here (edge of the East Anglia fenland) it continues to be quite misty at times due to the evaporation from still-wet ground (normally we don't get much rain - it's only fenland because it's at or below sea level).
The panels should get closer to peak capacity when it's cooler and breezier - spring and autumn.
Of course, in spring and autumn the days are shorter, so although the daily peak may be highest in spring and autumn, the total daily generation probably won't be.
sedgy34
  • #3
That's seems reasonable the hotter it gets its performance is slightly lower
K
kevhky
  • #4
I realised this but a psl of mine who lives pretty much 2 mins away had his installed the same time
he has a 3.9 system and same inverter as me 3.6 aurora and he is peaking at 3.6
He has 16 panels rather than my 14
To me it just dont add up
My system
3.36kw with 3.6 inverter facing south with no shade
Mates system
3.9kw with same 3.6 inverter facing east 6 panels east 10 panels west
Any thoughts
Kev
P
PengEF
  • #5
Mine was fitted about same time as yours. We are probably in different parts of the country so direct comparisons are not going to help. However last Sunday I had the best day so far and generated 26.7kWh. Was made up put the peak was way down at 3.4kW for a 4kW system facing SSW with zero shade. Now yesterday with a lot of cloud and the odd sunny spell I got 18.2kWh but it peaked at 4.06kW. Last Sunday with wall to wall sunshine the panels just got too hot. Yesterday and today conditions were right to get very close to the peak output at times but rubbish for sustained generation. Swings and roundabouts. Yours does sound low but it's almost impossible to say if something is wrong on just 2 weeks generating I would think but I am no expert.
B
babba
  • #6
Its hard to believe the SPLIT system of the OP mate is peaking so high ?
B
babba
  • #7
Why the 3.6 and not the 3.0 Powerone if you were looking for peak performance.
K
kevhky
  • #8
I agree but ive seen it for myself
Last Sunday was my highest 19.5kw generated that day
my mate generated 21kw
Its baffling how i have the south facing with no shade, yes i do have two less panels but i should surely be matching at least
My panels are REC 240w and his are Canadian 245w
Kev
K
kevhky
  • #9
Good stuff mate, obviously keeping a close eye like myself :0)
Like you say it is swings and roundabouts but i just want to see mine peak so i know all is working ok
Im from north east, UK
Kev
K
kevhky
  • #10
Well my panels are 3.36 so isnt that what i should peak at, im led to beleive thats the case
Kev
whinmoor
whinmoor
I would have been tempted to go for the 3.0 rather than 3.6 on this setup. Not much in it as you are caught between two stools but the lower rated inverter may be more efficient on cloudier days which are generally more common in this country. Maybe the 3.6 would be better down south and the 3.0 better up north.
K
kevhky
  • #12
I just went with what the company reccomended
The inverter has two strings but they only used one
Kev
Reply to New PV System performance in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
CK Tools :) The professionals choice when it comes to Electrical Tools
Top Bottom
