Discuss new tool in the Industrial Electricians' Talk area at ElectriciansForums.net
Brilliant .... so glad you took the time to give a reasoned and enlightening reply!
Anyway wadda ya think on me toy oops i mean tool?:p
Hi,
Hiya Matey ,how are you,right the bolloks comment was in reply to the fact that coax is similar to swa,the moons similar to the sun in that there both planets,
that said .i will now attempt to appraise your new tool,which considering i havent seen it ,is not easy
If i was a dragon ,and you were in the den ,i would ask these questions
firstly will it work ? and if so how long before it gets blunt ?
is it faster than traditional methods,
is it easy to use ,
what size of cables can you use it on ,
how much will it cost ,
how bigs the market ,
how much will it cost to manufacture ,
will it pass all the required safety standards
The answer to some of the above have allready been discussed,
Im sure somone will give it ago ,if it really does work ,i wont im affraid ,thats not rubbishing it ,its personal preference ,
i would even stick my neck out and say its not as easy or quick as the old way .it would have to be bloody quick to beat me in a race ,even if it did i still wouldnt bother with it
so there you are that,along with what i have said in previous posts is what i think of your new tool
and as i said before all the best with it:)
I have just bought one of the kewtechnik units they had a poster in the factors so i bought one. Rumour is it doesnt work that well bu i will give it a go and see how we get on.
do you come across a bit of swa in your game then dragon ?
SWA is like coax,dragon said so in an earlier post maybee hes going to try it out on coax first then move on to the big stuff , i think the stripper only does up to about 16mm but thats "Quite big";)
have loads a fun with it anyway:)
well this week i am all about the SWA, and it is like coax just larger the kewticknik tool is no more than a sheath remover and far less advanced than the coax stripper i use
Slightly disapointed with some of the replies I've seen on here.
The guy only asked for peoples opinions. No reason for him to be slated.
Reply to new tool in the Industrial Electricians' Talk area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
G99 GSI-3 4.4 kw Victron inverter install with EES and batteries and installer can set the export lint if required by dno As part G99 GSI-3 you...
Hi guys, I'm trying to find a definitive answer on the use of 1.5mm 2C+E for power points in a transportable structure which is fed by a 15A inlet...
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
