Aico Carbon Monoxide Detectors
Discuss Newbie who wants to replace bathroom extractor fan in the The Welcome Forum area at ElectriciansForums.net
hey, so im a DIYer and learn most stuff from youtube tutorials. At the moment am doing a bathroom renewal, and want to replace the extractor fan for a stronger one. I've a very basic understanding of house wiring and electricity, however i think i could do something straightforward like replacing an extractor fan, if i know follow the instructions.
My worries are getting the right power rating fan, so could you guys give me some advice on this?
Electrical2Go - Online Electrical Supplier
Wilko
Hi Fatah and Welcome to the Forum!
Can you tell us what fan you’ve got now? (perhaps upload a pic).
Midwest
In my experience, unless your running a rain shower, a Turkish steam room in your bathroom or have a really large bathroom, most of the typical bathroom fans you can buy will suffice.
Where they struggle, is too long or complicated ducting and vent to outside in the wrong place.
B
Bobster
An make sure enough free air can be pulled into the room to replace what is being extracted.
A small gap under the door will usually be sufficient.
O
Octopus
Why do you think you need a "stronger" fan?
Do you leave the window open too?
Do you have lots of condensation/mould in the room?
Does your existing fan actually "draw" air into it?
Can you feel air exiting from the vent with the fan on?
Is the gap under the door big enough to draw enough air into the room?
Does your existing fan continue to run after the the light is turned off?
telectrix
Mentor
rule 1..... isolate supply at CU and test for dead.
rule 2.... take a photo of connections before you start.
rule 3 ..... panic.
Tony Reidy
Most fans have around the same output if they are on an external wall and should be set to run on for 20 minutes to change the air in an average room, if its in ducting then you should use a centrifugal fan
  • #10
i live in a council house, so they dont replace anything until its broken, even if its degraded or barely functioning. we've temporarily attached a corded fan onto the existing fan, so its hard to see it, but definitely a cheap and old type.
  • #11
hi, my bathroom is roughly 2.5 x 2.5 meters, however;
-it doesnt have a window
-the door is usually closed at all times
-people take lo~ng showers
-decorator (my brother) decided to use wallpaper everywhere(including the ceiling)
and the current fan is barely functional :p
  • #12
i'll try and see if we can have the door moved upwards slightly, great tip!
  • #13
i think i need a stronger fan because;
-there's no window in the bathroom
-people take long showers, so lots of steam
-the existing fan is barely functioning
-i'm thinking to move the door upwards because current gap is small
-current fan keeps spinning after light is off
here's a some visuals bathroom - https://Upload the image directly to the thread.com/a/RQkEV7c
thanks}
  • #14
rule 3 ..... panic.
cmon i wouldn't mind doing that, only problem is that some fan have different amp and volts and i'm not confident about that stuff~
AJshep
That fan you had was not a cheap fan it is a Greenwood Airvac CV2gip. They are known as continuous extractor fans, it should have been commissioned on install and flow rates set up for low speed and boost, these all have humidity and timer overrun options built in if a switch wire from the light has bern used.
If you do the calculations as per Part F in most modern propertys a standard intermittent extractor fan will not comply unless you have enough background ventilation and single glazing.
See the video below but I would select both humidity and Timer overrun options
Midwest
I got them in my new build house. Not bad fan, except I’ve had to turn off the humidity option on the ones in the kitchen and main bathroom, ‘cos it kept turning on the fan and then never turning off. Probably faulty, but not good 2 out of 5.
Also had to turn the trickle down to minimum, as could stand the noise.
  • #17
hi, thanks for the useful info, but i'm interested in getting a manual fan with a higher flow rate. my bathroom has no window and people take long showers, the current fan almost never speeds up and i have to remove the front plate cover every time just to temporarily increase the speed. :(
  • #18
Midwest
I don’t know what you have done there, but it looks unsafe.
If that Greenwood fan still works, check its set up properly as @AJshep said. If you can get to the ducting, make sure it’s been installed properly, not squashed or full of debris.
Wilko
For the Electricians reading this thread - the installation instruction says the fan normally requires a 3A fuse unless it’s connected with a 6A breaker. Top marks for common sense :)
Tony Reidy
Is the fan in the shower (zone 1) if so it should be 12 volt
Charlie_
You mentioned the council only replace broken items..
Tell them it is broken.
Tony Reidy
cobblers. a 230V fan is allowed as long as it's IP44 or better. would you insist on a 12V shower unit in zone 1?
Fair comment never thought of it like that
Rpa07
‘Press the minus button 27 times - for the purpose of this video I shall only press it 4 times’ - no staying power, that girl, though I did mildly fall in love with her voice!
Looks like a good fan, Fatah - i’d certainly make sure that it’s not working correctly before doing anything drastic.
Check the ducting and the outlet as the members have said.
James
Mentor
Supporter
one thing worth considering, there is no other way that steam can exit the room.
do not expect any extractor fan to keep a room free of steam and moisture whilst you are having a shower or immediately after.
your room contains around 16,000 litres of air, assuming that you have a good supply of air into the room, either from a vent or under door etc it will take 15 minutes to do a complete air change of the room,
because of mixing of the air (dry air drawn in and damp air inside room) it will take 2 to 3 changes of air for the humidity to reduce to a low enough level to prevent condensation on cold surfaces.
your fan should be running on at full speed for 30 to 40 minutes after showering before the room will be dry.
if you are wanting the room to stay steam free whilst you are having your long hot showers, then I suggest a 300 to 400mm fan and ducting will be sufficient.
Note: it will be draughty and if the door is not closed properly it may pull open with the airflow!
telectrix
Mentor
there speaks the prophet of doom^^^^^. :D:D:D:D:D.
Reply to Newbie who wants to replace bathroom extractor fan in the The Welcome Forum area at ElectriciansForums.net
Aico 3000 Range
Top Bottom
