one thing worth considering, there is no other way that steam can exit the room.
do not expect any extractor fan to keep a room free of steam and moisture whilst you are having a shower or immediately after.
your room contains around 16,000 litres of air, assuming that you have a good supply of air into the room, either from a vent or under door etc it will take 15 minutes to do a complete air change of the room,
because of mixing of the air (dry air drawn in and damp air inside room) it will take 2 to 3 changes of air for the humidity to reduce to a low enough level to prevent condensation on cold surfaces.
your fan should be running on at full speed for 30 to 40 minutes after showering before the room will be dry.
if you are wanting the room to stay steam free whilst you are having your long hot showers, then I suggest a 300 to 400mm fan and ducting will be sufficient.
Note: it will be draughty and if the door is not closed properly it may pull open with the airflow!
