Discuss newbie in the Industrial Electricians' Talk area at ElectriciansForums.net
J
jamesie
New to this site, just got a bit of a problem that i need a little help with.
100 amp 300 ma time delayed RCD feeding DB with 100 amp 30 ma RCD as main sw.
3 phase band saw fed from DB. Saw works fine until dc brake is hit and then main RCD trips. bypassing RCD on DB.
Surely the 30ma RCD should tip before main RCD.
If that makes any sense! any ideas.
cheers
jamesie.
Reply to newbie in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Hello all I have recently installed a sub main in 4mm 3-core SWA, approx length 45 metres, to feed a small garden office. Final circuits in the...
The garage is 17 mtrs x 15 mtrs in the UKh The house has a 100 amp supply to the house consumer unit. The garage consumer unit is fed from a...
The seller is saying they will not upgrade the electric and it is normal to have 100 amps. However the inspector is stating it may trip often and...
Hi all, So I’ve been having a strange fault in my house which has just appeared over the past few days. About a month ago I moved my pc set up...
14K
