P
p11jor
Hi all
Just wondered if anyone could clear this up for me, I have a assesment due on 9th June, was going to use my garage as one of my assessments, it has a brick shed attached to it also so my plan was ......
Run t+e from main dis board from a 32amp mcb to a garage consumer 63amp rcd protected, then from that run a radial/ring for a socket circuit, say four or 5 sockets (probs do a ring to show him that I can test con on ring final) although if you have a testing qual I believe they don't ask to do many tests? Is this correct? .... Then I will run a lighting circuit from the garage board, only two light fittings though one in garage one in shed, may make them two way switching to prove competence.
Does this sound ok for one of my assesment jobs? The other will probly be a dis board.
Also on this would you run a new cable from oringinal dis board to the new garage one to save or would the cabling for the new circuits from the new garage consumer be ok? At present the original cable just goes into a junction box and....well you can imagine the rest....goes off here there and everywhere!!
Thanks for any advice in advance.
Phil
Phil
