Discuss Nightmare Jump Start - Peace of Mind Needed in the Auto Electrician Forum area at ElectriciansForums.net
This morning a friend's car battery was flat and they needed a jump.
I left them to set up the leads and got in my car and started it. Within 30 seconds, I smelt and saw smoke. The jump lead was on fire.
Immediately after getting out of the car I realised negative was going to positive, positive was going to negative. We must have had this set up for 30+ seconds
Turned the car off immediately.
Once everything had cooled down, I started my car with no problems. No visual damage to the ECU, and everything seems to be working. There are no engine warning lights.
I just drove home (100+ miles) and haven't experienced any problems.
I'm incredibly worried I've done untold amounts of damage, but I would have expected to see problems immediately if that was the case. (If the ECU had burnt out I would have at least expected a light on the dash, and the fuses seem to be ok as everything electrical I am able to check is working fine)
Have I just been incredibly lucky and got away with it? Or could I have done damage that isn't noticablen yet and will come to haunt me.
I'll be taking it for diagnostics asap but I've got to drive another 100 miles tomorrrrow before I am able to.
Please advise! I appreciate any advice anyone can give!
Many thanks
Negative to negative and positive to positive is the correct combination .
It is likely that you have had a poor connection or inferior quality jump leads. Depending on the vehicle and the amount of discharge on the battery , you could be drawing in excess of three hundred amps on cranking , that is enough to fry any poor insulation on the jump leads.
If this was the case it is likely that this is all that would be damaged.
Sorry! Edit made! It was connected Negative to Positive and Positive to Negative, causing a massive amount of current to burn the plastic on the leads.
You have been very lucky then . It is a wonder that you did not have a serious incident on your hands. The battery could have exploded spraying acid on the person connecting the leads.
If the battery you were trying to boost was completely flat you may have got away with it , and I suspect it was as the battery would have flashed over immediately the connection was made . The flat battery would take a reverse polarity charge and would likely be damaged.
Sounds like there were a few sparks intially (maybe not a fully dead battery). Any chance the good battery is damaged aswell or just the dead one?
I would say your car and your battery would have a good chance of surviving , but how has the other car faired , did you ever get it started?
The cheaper your leads ,the better chance of no damage !
( ECU's spike even with the correct polarity )
Is his alternator still charging ? (is a good question)...
May have shunted -power !
..If drains quickly over night
a) Battery now shot
b) Something is damaged and taking power when off.. Alternator classic
The other car didn't start after that unfortunately. It's likely it's killed it. It's a £300 beater on its last legs, we are more worried about the damage that may have been done to my car.
The other car is pre 2000, so we are replacing the battery and ECU, if this doesn't work it'll be a scrap job.
a) Battery now shot
The alternator of mine (good battery) or the other car (bad battery) is likely to be the one that's damaged?
a) Battery now shot
If after 100 miles you have had no problems and your alternator is not showing the warning lamp there is a good chance you have got away with it. It seems his car has taken the brunt of the reverse polarity.
If your battery was strong ,and his weak ,your battery probably will survive. His alternator is at risk , since his battery was most likely to reverse polarity !
As for your car charging -fans should speed up a little
and lights run brighter with engine running (..or a cheap
voltmeter ! rising to 14.0 14.4 ish ) and no warning light !
Reply to Nightmare Jump Start - Peace of Mind Needed in the Auto Electrician Forum area at ElectriciansForums.net
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
Good evening all Ive got an old truck 1990 that has always had intermittent starting issues whilst ive owned it.. As far as i am aware the...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
