Discuss NIPON SOCKET OUTLET in the Electrical Tools and Products area at ElectriciansForums.net
Is this a typo for Niphan?
See Plugs & Sockets - LPA Group - https://www.lpa-group.com/product/plugs-sockets/
Long-established design, goes back to the 1920s/30s. Popular on mass transit and high durability installations. Expensive, not sure they represent great value any more with so many good connectors to choose from. There are imitations, only the LPA product is the original Niphan.
Thanks, Lucien at least someone is helpful on here and not going off topic before it started. I only spelt it the same as someone email it so could be spelt wrong.
These sockets are for Christmas lights in a market square mounted on a lampost.
No Pete not a bad day at all just don't know what one was and its ok going off topic but when it is the first reply there would be only one way the thread will go and I will never know until we get it. This project bit of a council wasting money vanity project lights in the pavement under benches etc and nobody is thinking practically the job out. These lamposts are only 4Mtrs high.
you have to forgive buzz. he could not keep on track if he was a train. :mask: :mask: :mask:
If it's the ones I'm thinking of, they are used for high traffic areas, why they don't use panel mounted Commando ones only they will know, like you say more waste of the public purse, good luck with it any way, you going to Elex in Sept?
Well at least they've got that right. Originally made by Simmonds Bros. and even older than I said earlier... the original design was pre WW1, i.e. now over 100 years old. Probably one of the first comprehensive systems of truly watertight connectors, and perhaps the first to offer multiway splitters, 2, 3, & even a 6-way version like a pipe manifold, with a plug at one end and two rows of 3 sockets.
See: Simmonds Brothers - Graces Guide - https://www.gracesguide.co.uk/Simmonds_Brothers
I have them in use on various things; a WWII generating set, a 1930 film projector, a 3-phase distribution system for synchronous camera motors. The projector uses a non-watertight version without the locking ring and gasket, up to 7 pins.
They turned up on site so I thought I would post up the one on the lampost is an existing one that does not fall in the scope of works.
The only comment is that there is no cord grip the flex/cable is connected and hangs down inside the lampost.
A few years ago, I recall one of the Uni venues in Oxford with a very old installation, that only had these and 13s. The advance read "1 x 60A socket downstage left" or similar. I incorrectly thought, they must mean 63/1 ceeform. After a frantic 15 mins or so, the venue found a short 60A Niphan plugtop to 63/1 ceeform jumper, so all was good. Lesson: the devil is in the detail.
Reply to NIPON SOCKET OUTLET in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Apparently Dimplex only guarantee their heaters if they are permanently wired in to a fused outlet. If the socket is only about 600mm from the...
Hi, after some discussion with electricians, does removing a 16A or 32A socket constitute safe isolation? I understand that removing the socket...
Has anyone heard of company called Scimark making domestic switches, outlets etc? We live in a house built by David Wilson Homes who...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
