- Reaction score
- 984
If that’s not possible put the whole circuit on a 20A MCB and note ithe would have to make the split between the 2 sockets that each have a N from each leg.if that makes sense. i.e cut out the section where the N is broke.
Discuss no continuity on ring final neutrals in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
And leave a potentially damaged cable in service?If that’s not possible put the whole circuit on a 20A MCB and note it
Reply to no continuity on ring final neutrals in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
