Discuss No lights working in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dave66316
Hi im after some advice please,
I tried to change a light fitting in my living room from a standard ceiling rose to a new light that I bought, now the problem was, the original rose has 9 connections, for the three cables comin through the ceiling, which I now no to be one from the switch then two from loop, I think, but the new light had only 3 connections so I put all the lives to one all the neutrals to the other and all the earths together, turned the light on and it worked perfect
But then when I turned it off there was a pop from the light switch and the switch turned itself back on, but now no lights work anyway, all the lighting is on one fuse, which hasn't blown,
I have now put everything back to how it was, but still no lights work,
The house is 100 years old, with new and old wiring dotted about,
Any help would be much appreciated, thanks
Youve got your wires crossed,as others said call a sparks before you get hurt,what area are you in?maybe someone on here is local to you.
Hi im in southport, would anybody know the general cost of what its likely to be, as were both skint, and got a baby due tomorow, and could really do with some lights, thanks in advance
if you werew local to me. i'd charge £30 - £40 (plus any parts on top)
actually. southport's not too far away., i've nowt on today, so i could come up there and fix it for you.
cuddington. just west of northwich. phil.you're closer to southport than i am.
nice one. and best of luck with the birth and the new carpet crawler.
Reply to No lights working in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
I put some news lights in a bathroom and new extractor fan. Did the tests and filled out form. A couple of days later another electrician came in...
