Discuss no main switch in DB in the UK Electrical Forum area at ElectriciansForums.net
leep82
Came across a scenario today where the consumer unit had no main switch. It was a split load dual rcd board on tt installation. The incoming tails had been taken into one rcd, and connected in parrellel over to the other. There is a double pole isolator right next to the board, but nothing actually within the board that would isolate the whole installation, this doesnt seem right to me any thoughts or advice?
I can't think of a particular reason why it wouldn't actually comply, perhaps not ideal though - but at least the whole board can still be isolated with the adjacent DP isolator. Maybe the CU originally had a 100ma time delayed RCD as the main isolator and has been 'upgraded' at some point to 17th edition spec ?
Nothing wrong in my opinion as you have an adjacent means to isolate the board fully, I assume it is marked up as such to avoid any confusion unless its obvious.
did you take a picture?
had the main switch been removed to accommodate extra circuits?
The installation is two doors down from a job ive just done ( neighbour saw my van and asked me to look at some work ), and for which i asked a question on here. The original job had a 100a 100ma time delay rcd acting as a main switch, and the same double pole islolater adjacent to the consumer unit. I left this in place and installed an additional 100a 30ma rcd, protecting the circuits i had worked on.
Seems sombody had beaten me to this job, and gone about it a different way. It struck me as being unusual, but the more i thought about it i questioned what was actually wrong with it, and that its actually a better means if isolation as it isolates the whole board as opposed to just everything from the outgoing terminals of a main switch leaving the incoming still live.
Reply to no main switch in DB in the UK Electrical Forum area at ElectriciansForums.net
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Need some advice, I have 7 static caravans to connect which need to be connected via TT 1. All the vans have a 30ma RCD main switch internally...
