Discuss No power to CU or meter after resetting RCD in the UK Electrical Forum area at ElectriciansForums.net
I was working on a lighting circuit connected to a 3 phase board. The board has a single RCD effectively acting as the main switch. After tripping the RCD by cutting a wire (the old circuit isolated via MCB but Neutral still connected reason), I found that the power to the board didn't come back on after resetting the RCD. The meter was also dead.
The service head is in another premises (where the power was still on) and I found that cycling the power off & on from the upstream premises seemed to reset something & power was restored to the DB & meter where I was working. This is a TT system. The owner of the other premises was unaware of any other infrastructure in-between. I found this to be repeatable.
I would like to understand what happened here.
Has anyone else come across this scenario who could suggest why this happened and how cycling the power brought ?
I was afraid someone was going to ask that question. The owner of the premises was talking confidently about it as if it was an RCD, saying it hadn't tripped, but it looked more like some form of isolator to me - a square grey metal box with a white up down switch. (He was a bit dismissive & the situation didn't encourage me to linger). The box was quite large in proportion to the size of the switch.
Many thanks guys for your replies, which I will research further. I hadn't heard of an MCCB with tripping coil before - I wonder if this is something that you are more likely to see in a 3 phase scenario.
Yes fairly common, you can buy add on earth leakage kits for when you need earth leakage protection on supplies >100A
I did have a photo of one in the dodgy trade pics thread but it is gone now.
I'm intrigued is it you on the unicycle.
....thought i was off,on a 4 pole voelcb debate.....?
Yep,it's me,many years previous,demonstrating balance,strength,and the dangers of weird company and too much free time?
I can still do that,but at 55,you have to realise the change, in things like responsibility and healing times.
I could do the same foolishness,with an old full size acetylene bottle,which is quite a bit heavier,than an oxy bottle,but did have a pedal shear off,on one occasion?
...come VERY close,to needing the unicycle,surgically removing,from me lower colon ??
Reply to No power to CU or meter after resetting RCD in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I'm a newbie to the forum, and I'm hoping my question won't be too stupid. I'm in NYC (Manhattan), and have an apartment where a...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi all. I have a power outlet that has no power coming to it. The breakers all appear to be untripped (I turned them off & on again to make...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
