Discuss No socket for gas hob in the UK Electrical Forum area at ElectriciansForums.net
stratplus
Improvisation, what do you think?
No it's not ok, and it is a particular bug-bear of mine. A plug is designed to have one flex connected to it, the cord grip is designed for one flex and the terminals are designed for one conductor. And for 13A plugs there's barely enough room in there for the one cable sometimes.
Just to the right there is a cooker connection plate! Wonder what they could use that for???
Answers on a postcard please plumbers :rofl:
Don't be daft, Paul.........why do you think there's a third flex......not got the cutters out yet.:6:
As a means of last resort, one of those 1 gang to 2 gang converter wall sockets could be used. Not too sure if the 3 gang versions will fit a single outlet, but then they do make 3 gang plates and surface back boxes now.... lol!!
Surely not thinking of swapping it for another 13a socket are you???? lol:6:
I haven't read the new edition, but in the last code of practice for II&TEE it specifically said you can't do it. There was even a picture.
Good!
As I said its a particular bugbear of mine.
Earlier this year I got called to look at a reported electric shock incident. It turned out the 2 pieces of equipment involved were fed from a 63A SP adaptor made with a commando plug with 2 flexes in and 2 trailing sockets!
We see a lot of these at 16A in the theatre world, and the occasional 32A but this was my first 63A!
Another one that crops up too often is the 32A plug to 2x 16A socket.
Good!
Ah yes, the 'theatre world', where seemingly anything goes. I used to do a bit when I was at school - we had a 63A plug with a bit of 10mm T&E to a bit of plywood with 3x double sockets on it. To be fair it did have an RCD on it so whoever put it together had some sense of safety at least. It always struck me there should have been more sockets installed in the place - there was 1x rcd socket on stage right, none on stage left except a cleaners socket forward of the proscenium arch, 1x double socket under the stage which we used for the amps, and 1x double socket on the balcony/control room which fed all the lighting and sound equipment, and a 2k followspot. Fortunately it was all wired in MI.
Once, for a larger production, we slung an extension lead out of the window of the 6th form block next door and through the window of the hall. They could have been on different phases, who knows? Nobody was killed though.
Reply to No socket for gas hob in the UK Electrical Forum area at ElectriciansForums.net
We have an install where the client has supplied an induction/gas hob combination unit. We have a 6mm cable supplying the hob, the induction part...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hi all. I'm currently building an island in my kitchen which will contain a gas hob. I've cut a trench about 60mm wide from the edge wall to...
Just wondering what everyone’s view on this is, if you’re mourning cooker or hob switch in cupboard close by. Would you still terminate into an...
