- Reaction score
- 2
Hi everyone, I've come here in frustration and would be so very grateful to who ever can help me..
The lighting controls are required to: Dim hallway lighting (9 x GU10 LED) after 10pm untill 6am to 50%. The rest of the time NO dimming is required.
To complicate this, these lights are switched with a PIR (there is also a single 2way switch that is used to allow for permanent override)
The current setup: I am using a time clock to operate a double-throw relay to switch a dimmer into the circuit. So before 10pm, the PIR switches as normal through the N/C of the relay. After 10pm, the PIR switches through the N/O of the relay, energising the dimmer switch...
HOWEVER! I did not foresee that the dimmer switch would reset when de-energised and require physically turning on making the whole thing useless!
I have rang round several technical support persons and not getting anywhere, so I'm asking if anyone knows of a dimmer product that can stay energised or stay locked in its mechanically set position??
Obviously, ANY viable solution would be awesome!
BUT as you might realise, this setup is a way of not spending too silly money on various smart products or more commercial setup solutions, and a way of using the PIR's already in place.
Many thanks in advance.
