Discuss NOBO heater wont switch on in the DIY Electrical Advice area at ElectriciansForums.net
J
jrhall88
Hi I would like some advice in my flat I have two heaters in the living room these two work fine but the ones in each bedroom don't work I have swapped the fuses round and the ones in the bedroom still dont work can anyone help ? I have no idea what make it is the instructions I have for it don't say much apart from E2E/E2EZ/E2X E4E/E4EZ/E4EU/E4M/E4X some one help please i have attached some pictures
I am sorry but without being there and doing some testing there is little advice available.
The heaters may just be broken.
The fused spurs may be on an economy seven timed supply and so only on over night, though this would be odd for those sort of heaters.
there may be no supply to the fused spurs, either because a circuit in the fuse board has tripped or because of a loose or overheated connection at the spur.
Because two heaters are not working I might initially expect that the supply cable has become disconnected prior to the first non working heater in the circuit, however the design of the circuit and the points that are live would be needed before making a judgment.
Assessment of these items is probably somewhat out of the scope of a normal DIY approach and may be hazardous to attempt unless you are competent in this field.
Reply to NOBO heater wont switch on in the DIY Electrical Advice area at ElectriciansForums.net
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
Hi, Because of the recent epidemics of so called experts with absolutely no proper qualification, nor knowledge, I'm forced to learn more on the...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hi New to this forum, Just looking for some advise as a DIY person. I have recently purchased a new home. I have come across a wall light which...
