Discuss Not properly grounded/earthed in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
dd4545
Hi All
I know next to nothing about electricity and wanted to ask for some advice. Apologies for any cross-posting.
I moved into a rented house in Spain a few months ago. Turned out it wasn't grounded. Providing a ground turned out to be a little complicated as the property is build on top of a few meters of concrete. The makeshift solution was having this house attached to the grounding rod next door (landlord's own house). However, I was still getting shocked (continued hot tingling upon contact sort of thing). The electrician investigated and said there was still 8V hanging round that wasn't being discharged through the rod, or something like that (perhaps insufficient capacity for two houses?) Anyway, he was adamant it was nothing, that I should shut up. The landlord wanted him to put in a separate grounding rod for this house anyway - and the electrician says he will - when he gets time - and this is, he said, a very low priority job.
Things can move slowly out here. It's been ten weeks and he's yet to have time. For a couple of reasons, the landlord is reluctant to change electrician, but if I should I can put on pressure, either for the original electrician to come out, or to find someone new who is bothered to do something. I do still get shocked when I come into contact with metal things plugged into the mains, but I've been promised that at this voltage (8V) it's not even worth saying ouch over. Also, I assume, it will not be doing any damage to the electrical appliances I currently have plugged in? So do I just wait? Or should I insist this is sorted ASAP?
Thanks in advance
1.Is there a working, tested, RCD to ensure these shocks are not potentially lethal and just unpleasant? 2. It usually takes more than 8 volts to be noticeable. 3. It shouldn't damage your equipment, but if connecting any of them together, I'd leave at most one plugged in before fitting the interconnecting leads; this is a normal precaution anyway as ordinary (EMC / interference) suppression capacitors in double-insulated TVs and "set-top" boxes and laptop computers can give enough current to blow up HDMI connections, etc. while still being well within accepted (human) safety limits and compliant with the products' safety standards, and can give quite a tingle when all plugged in, regardless of the earthing arrangement because they, being class II, aren't even connected to it!
Reply to Not properly grounded/earthed in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I made a DIY light fixture by putting some cut-to-size LED strips in an aluminum housing connecting them to a Mean Well DC power supply with a...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
Good Afternoon All, I moved into a flat around 2 months ago. A few times only (maybe four times in the two months) I've turned on the kitchen...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
