Discuss NOT SEEN THIS BEFORE. ASSUME PME??? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
as title.cable tapped into N, disappears into the ground. assume to a rod.
Presumably now at least PNB!
That "crimp" can't have been left like that (is one of the neutral strands snapped?); it does look like a cable could have been connected to the next joint along the cable at some point, maybe this was a method of restoring back to how it was.
Not sure this is an approved method of applying TNCS for an incoming supply.
well it's a DNO bodge then. this house is the last of 6 on the run. . none of the others have antything like it.
back there today. will measure Ze, PSCC, and PEFC.
If it's the last house of the run, it will be 16mm hard drawn copper down to an earth rod as per DNO PME regs. Should have a PME label attached.
Reply to NOT SEEN THIS BEFORE. ASSUME PME??? in the UK Electrical Forum area at ElectriciansForums.net
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Evening all, I have a little conundrum I need to get resolved. I’ve moved an EV charger from a single phase board that was on a 40a breaker and...
Morning guys, Just been to look at a CU change and there was a bit of an oddity with the PME connection in the old black cut out. Looking at the...
