Discuss Novice wants to add led interior lights in the Auto Electrician Forum area at ElectriciansForums.net
Hello I require a little advice. I'm looking to add some rgb led light strips to the interior of my car. I want them to power on when I open my door. That bit I know how to do. But I also want it to be powered by a switch that I can turn off
Welcome to the forum.
From what you are saying.... correct me if I'm wrong, you want a led strip to be activated with either the door switch or a new switch you will fit???
If that is the case the can you not just add the new switch in parallel with the door switch.
Also making sure the led strip doesn't draw so much power it blows the relative fuse.
You might need to use a couple of diodes to prevent the interior lights also being switched by your new manual override switch, unless of course you want all the interior lights on at the same time.
Excellent. So basically I can hook the 2 different power inputs into the rgb controller then on the interior light wires just have a diode to stop the power also going to the interior dome light yea? I only kind of know what I'm doing ;D flying blind so all advice is actually very helpful
Red for drivers door, blue for passenger and green for the boot?
Do you want the lights wired same as the courtesy light? Ie switched on/ door switch/ off?
I'm thinking something like this....
The exact design would need to factor in how the interior lights are connected to the door switches and whether they simply switch to chasis, which in a lot of cases is the negative terminal of the battery (but not always).
Reply to Novice wants to add led interior lights in the Auto Electrician Forum area at ElectriciansForums.net
Hi everyone, On my Hiace the roof LEDs are triggered by the side door that breaks the ground, not the positive wire. I want to also have an...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi, I want to put downlights in my fire surround - possibly 3 but more likely going to be 2. They are 0.4w LED lights. I have a 12v 8w LED driver...
Hi everyone. I should start by saying I'm not sure I'm in the right place here (this isn't a householder issue - I'm making a Ghostbusters...
