Discuss Odd Polariy Problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sivoodoo
Hi All,
Was testing a domestic installation prior to fitting a new cu:
1, No continuity on what appeared to be the a ring (was wired as a ring at cu), when i removed one of the legs (leg 1) I had L N reverse polarity at a spur (wired correctly), when I replaced the second leg (leg 2) at the cu the polarity was back to normal? Why would this be?
2. As mentioned there was no continuity between line conductors. But I had a reading of 20 Ohms between leg 1 and neutral at the neutral bar.
The house is a huge old place and has redundant circuits all over the place, bit of a nightmare to be honest rammed full of junk etc and difficult to get access.
Any ideas on the polarity issue,
Regards.
Simon
That continuity treading of 20ohms between L & N could indicate this is an Immersion heater feed and has been incorrectly wired up with one leg of the ring ...the other leg could be wired into a seperate fuseway. Try continuity test between leg 2 and any other 2.5mm2 cables at the board.
spark1
Thanks for he reply,
"Try continuity test between leg 2 and any other 2.5mm2 cables at the board."
I did that and got nothing, though Im off back on Thursday to take the place apart! I may be some time.
Regards
Reply to Odd Polariy Problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
