I
Inteificio
Hi,
bit of a rush job, but when double checked by me, then another spark could not work out what I did wrong.
Needed a r1r2 reading on a feed from one of our DB boards to an isolator about 10m away. This circuit has been live for some time, just a double check was needed (d63 breaker was on it, we had no idea why, wanted to double check).
I isolated and locked off the supply at the DB board.
I linked l1,l2,l3,R2 at the isolator all at once (far side of the breaker as access to near side was very tight.)
When I went to do the r1,r2 at the DB board it worked fine on friday. Did it again yesterday (accidentally left paperwork at home so had to redo).
When I did it monday morning, when checking the resistance the breaker kept on tripping on the isolator. These wires are locked off and not connected to supply. The N was not touched at either end. The E was in contact at both ends (so not excluding parallel paths. breaker trips 3 times. hopefully unrelated there sounded like a electrical bacg from inside the wall and potentially at the same time a piece of large machinery on the other side of the factory trips the RCD.
I do not get what is going on!
What am I overlooking.
