Discuss Ok to sell without detachable lead? in the UK Electrical Forum area at ElectriciansForums.net
They must meet legal safety requirements and I suspect that would apply whether the cord set was supplied or not. Printers and the like do not use kettle leads although they appear similar. A kettle lead uses a connector known as a hot connector and has a key way to it to prevent IEC leads from an item such as a printer from being used in a kettle because although they all look the same IEC connectors can have variable ratings. So a kettle lead will fit a printer, the IEC lead from a printer should not fit the kettle but it is quite rare to see a kettle with lead these days they normally sit on a kettle base.
Reply to Ok to sell without detachable lead? in the UK Electrical Forum area at ElectriciansForums.net
