Discuss Old Cable colours in the UK Electrical Forum area at ElectriciansForums.net
Hi all
Any regs that allow use of old colour cable ie-- red and black if sleeved with new colours (brown blue)
Just found full drum of 10mm in back of my garage and be great if can use it and sleeve to new colours
no reason why not. ( or date the cert 2004 :dizzy::dizzy::dizzy:)
i once bought a 100m drum of 2.5mm in R/Bk from a car boot. ( c. 2011) for £10. soon got used.
yous be able to wire a few 10.5kW showers at a competitive price.
Must admit board change I did this week (another thread) I extended some 1.5 blacks using some new black from old stock. Made sense as much of the 80s wiring had blue line conductors.
I'd personally weigh it in or flog it. I'd not be using it for new jobs.
Omg , no way would I scrap a perfectly usable reel of new cable.
I still have loads of red and black singles from when my dad was a factory electrician. I could never just scrap it...
I would have no hesitation whatsoever to use old colours:cool:
The only reason I would not do so is if the copper cores had oxidised,the insulation was somehow or other damaged or for some obscure reason I had run out of identification tape or letters
Having said that,I'm open to changing my opinion if I was provided with a justifiable reason(other than "they are not the current colours") :)
Reply to Old Cable colours in the UK Electrical Forum area at ElectriciansForums.net
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
I’d appreciate your professional views on this question, as I’ve had 2 of the associated electrical bodies quizzed on this.!!!! ON changing/up...
Am fitting a new pir led floodlight . The exsisting light is connected to 4 core round flexible cable, core colours green/yellow, blue, brown...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
