Discuss old light switches in the Australia area at ElectriciansForums.net
M
Mike Watters
guys in an old house there are lots of single gang light switches that have 4 connections. live in , neutral in then switch live and neutral going to the light. av u seen these b4 and what do i replace them with.
if you're just replacing the switches, block connector in the neutrals. check also that the neutrals are not fused. but if they work, why replace?
No problems.
If using double pole switches, wire your new switches the same as the existing ones. Supply lives on one side, switched lives on the other.
If your not using double pole switches and using normal 1g1w switches, join your neutrals together, then supply live(s) into COMM, switched live into L1.
Reply to old light switches in the Australia area at ElectriciansForums.net
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
So, I was messing around yesterday with some old testers I have laying around to see if they still work I found my dads old Robin MFT and noticed...
