Discuss Old MK sockets? Classification code or not? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Deleted member 4632
D0 these old style MK sockets require reporting in an inspection? C3?
Just found this image as an example, obviously if there was thermal damage or the socket was damaged itself then I would note it but just as itself wondered if they needed noting. No issue with exposed earth terminal?
no shutters would also be a C2 in my book, but i can't ever remember seeing a 1363 without shutters.
C2 like the other lads.
Plug tops are half insulated on the live and neutral pins nowadays but they are some still out there that are not.
Anyway doesn't change my opinion on the code.
That's what I had initially put on the report before I questioned it. C2 with a recommendation to replace.
Yes but why, I agree with Tel the one in your pic does show signs of overheating but if the others are okay I would say they are fine surely they have shutters.
Are you talking about the earth pin not being shuttered, that is not a problem as long as the other two are and I find it unlikely they are not.
Reply to Old MK sockets? Classification code or not? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys Completed an EICR yesterday. One of the Sockets Radials had no CPC so R1+R2 plus Zs could not be not be completed. Does anyone know the...
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Looking for a metal pattress with screw fittings in the correct place for this old MK 2 gang socket. The existing pattress of the socket that I...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
