Discuss old timey bending block in the UK Electrical Forum area at ElectriciansForums.net
Not sure what's old-school about it, it's a useful technique for bending any pipe etc when you haven't got a bender/former to hand.
Just the right sized hole through a piece of wood, if you have a round rasp - take the bottom edge off the hole approximating the radius of the bend, it helps.
I have used it for the odd time when we couldn't be bothered getting the bender out - especially for the odd plumbing job (although you need an internal spring for copper pipe)
I used an EXTERNAL BENDING SPRING for Refrigeration pipework
Straight hole same size as conduit, to be bent
Away you go
I was taught at college that the hole in the wood had to be 1½ to 2 times larger than the conduit you were bending to avoid it jamming in the block, used that method loads of times with no problems
I used to have one in the 70's for 20mm. Drill the 4x2 ( 6" from the top ) a straight 25mm hole. With a 20mm tube heated with a blow torch, manipulate up and down to make formed soft edges. Ideal for awkward bends and also dressing many tubes in parallel.
I used a wooden block once years ago, you still need a vice for threading and cutting, might as well get a hilmor conduit bender.
Remember that old vice had a wooden foot plate years old ha ha.
I also use one of the above sometimes.
I've got a 20mm and 25mm of a similar design. They are a handy bit of kit for the odd bit of conduit on a job
Yup, mine is a hilmor - gm32/35 or something, only have formers up to 25mm though.
Reply to old timey bending block in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
Does anyone know if the new Contactum mcbs fit the old ones . If not are there any brands that do ?
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
Good evening everyone Can any help or give me some advice please on measuring bending galv conduit. My question is bending long 3m lengths...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
