Discuss Old Wylex in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
MEGGER?
Could anyone tell the correct BS number for main switch. I have been told that it is 5419 and also told 5486 .I know they are both withdrawn numbers but am still unsure.:confused::confused::confused:
In Domestic situations it is either BS 1361 or BS 88.
Thats the main cut out fuse BS numbers.
As to the OP, you got me thinking now and i cant remember!
I think either will be ok.
You wont get hung for using the incorrect one on a cert.
Ive got all this to replace on the weekend so if you can wait ill see if one is marked:D
Jason what are you going to replace that video tape with?..........
Looks like you will have some fun with that!.......planning on working late?
:D
The tape is no longer, as is the cupboard that its all currently housed in.
Going to be doing it over a couple of Sundays as the owner doesnt want to shut shop.
This is only a small part of a big refurbishment project planned for the next few weeks.
Few more pics to follow.
Might even start a new 'project' thread.
It will be marked on the switch.If it isn't it won't have a bs no,so leave it blank.or even better write N/M(not marked)
rewireables-BS3036 usually 1ka but can go up to 4ka.
:D
like that MET! Have fun.
Reply to Old Wylex in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
My builder has sprung a job on me. New circuit required for a hob. The CU has a single 30mA RCD, type AC. I am still unsure exactly when I should...
Hi there, firstly wishing you all good health and happiness 🙂 Just a few questions if you all don’t mind answering for me please.. I’ve just...
OLDBOY
O
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
What are people fitting in the 3 phase range just lately, I've had a scan at various makes and it seems to be a ---- up between Hager and Wylex at...
