J
Discuss Omron plc cpm2a in the Electrical Forum area at ElectriciansForums.net
hi than you for the response the plc is CPM2AFire away
Fire away
Hi it OK, only me . the student not speak English very well , i teach by doing, not talking so lots of practicalYou might regret saying that see how many of them there are.
yes i am using cx programer 9.4 spent all day just reading the manual looks like the problem with the (um) wasHi Julian.
What software are you using currently to program this PLC? Cx programmer?
You have kind of jumped in at the deep end with this one especially as you have no plc experience, there are many modern systems with simplified programming, computer based testing software so you can test your program long before loading up and with a logic block building system, far simpler than the ladder system which is now becoming old hat.
If you can tell us what method your programming in (logic block or ladder) and what kind of programs you are creating, I could probably post you a link to free PLC programming software which allows you to create and test your programs before you download to a PLC, you have a testing module there often used for proving functionality of a program, if you are then sucessful in writing your program you can then downlod it and run your plc while your program monitors it in real time thus watching your program onscreen as it works in the real world.
DW ladder is in no way antiquated, in fact it is still the most common format of PLC code. Yes it's a little more to look at than STL, SCL or Logic blocks.
Most modern PLC's convert all types of written programming into 'machine code' when compiling for a download.
Reply to Omron plc cpm2a in the Electrical Forum area at ElectriciansForums.net
