Discuss one way switch in the UK Electrical Forum area at ElectriciansForums.net
Hi all, need a bit of advice please, I am extending an outside light which is currently operated from a fused switch, the wires can be extended to the new switch easily enough but i am confused about connecting the switch, I have a one/two way switch as pictured
images
and I have twin and earth to the existing fused switch (which is in a stupid place) and a twin and earth to the outside light, how do I connect my existing cable to the switch ?
Lin to com. Lout to L1. Nin and Nout in a connector but not connected to switch. earths to back box and if faceplate is metal, earthto that also.
One side in common one side in L1 or L2 and the switch just breaks or makes the contact to take the live on to the light. Don't switch the earth and join the neutrals together in an insulated connector block
one would think that OP is coming off the FCU to a rocker switch, so it should already be fused @ 5A.
Reply to one way switch in the UK Electrical Forum area at ElectriciansForums.net
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
