Discuss Only 1 Fridge door tripping electrics help please in the UK Electrical Forum area at ElectriciansForums.net
Hi all Hotpoint American style fridge freezer model FFA40X keeps tripping the electrics not the lights when the left hand door is opened. It doesn’t do it if the ugh hand side door is opened. It trips if both doors are opened at the same time too. The fridge has been tested and all good. What could be causing the left hand door only on the fridge to do this. Any help appreciated thanks in advance
How was it tested, was the left hand door open? It could be a chafing cable that only touches at a certain point in the door movement.
there was a recall on out hotpoint. it's one of those with a demister panel flapin the left hand door. look atr the top of theleft door, hinge side. there's a flex going into the door. id chafes and shorts to the casing.phone hotpoint. they fix for free.
hotpoint don't test if that is the fault.they just replace the door.
Reply to Only 1 Fridge door tripping electrics help please in the UK Electrical Forum area at ElectriciansForums.net
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
