TheConduitKing
Trainee
- Reaction score
- 38
So abit of a random one. But yesterday my Neighbor asked me if I'd be able to take a quick look at their shower as it had stopped working. I said I'd go round an take a look and see if it was something simple enough to fix and get it going again.
Checked the usual things. The solenoid was fine, microswitch was working fine, no loose connections in the shower itself.
He said that it would work occasionally then would stop and that he has had to replace the pullcord 3 times in the past year
Took a look at the pull cord and noticed that the cables were mixed up. The supply was in the load and vice versa. I didn't see any burning, again no loose connections (this was a 45amp isolator.) And that one of the earth's were disconnected and wrapped in tape. Apparently it was like that the first time he replaced it.
I turned the power back on and got a reading of 170volts between line and neutral at the shower and 230 at the pullcord itself. The shower is fed by a 10mm cable covered by a 40amp MCB with RCD protection.
I just left it at that and told him to ring an electrician I know who can come out and test it to make sure that the RCD and all that will be working fine In case it's not working.Especially with only one earth connected.
But I'm confused. How can the shower only be getting 170volts at the shower when it's getting 230 at the pullcord? Unless it's broken?
Any ideas?
Any ideas?
