Discuss Opinions of this wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi there
Just after some experts opinions of this wiring of my consumer unit (image attached).
It was installed by one electrician who installed the attached, they were then meant to other jobs in the property but went AWOL. Anyway, we then hired another electrician who finished off the other jobs but commented that this installation quality was appalling and 'don't pay them other than the materials' He then had to redo a lot of the work on the attached.
Just wanted a second opinion, appreciate it's difficult to see in an image but want to be fair to everyone before I ask for discount. Is it that bad?
It looks untidy wiring to me but welcome your opinions...
Thanks in advance
We've seen worse on here, I'm sure, but yeah - that's pretty poor!! It would need an up close inspection to say for certain how many non-conformities existed. I can clearly see that it's been a board swap from a much smaller one (probably rewireable fuses??) and in doing so that cables have needed to be extended, but there's ways and there's ways!!! A better way would have been a small plain box where the original cables presented, proper DIN rail connections to new cable and then mount the new consumer unit directly alongside or underneath. I'd agree with your other sparky - pay for materials only.
Thanks very much for your input. Yes replaced a much smaller 1980s fuseboard well spotted! The other sparky commented on those plastic connectors they have used and ended up replacing them
Hold on a minute
Are those Henley Blocks ? Was this a Delroy job ?
First glance they look like Click blocks, yes. I'm amazed the cover managed to get back on!!!
Did you get a certificate from the first electrican, with a schedule of test results for all the circuits?
And did it get notified to Building Control (assuming it is domestic, this is required)?
Yes we did test first, and the test failed one of the reasons being to do with the old style fuse box hence this job attached. He then went AWOL but the second electrician made amends and signed it off with NAPIT
Edit turns out we did get an NIEIC certificate for the first installation, pictured. Then got a second one NAPIT from the second electrician who amended the mess you can see. I think it was then sent off somewhere possibly building control?
Horrendous.
A total mess.
Hensley blocks inside a CU. Never seen that and I’ve seen a lot.
someone has no pride in there work at all. disgusting.
Seen quite a few Celebrity electricians change boards on youtube and put henley blocks inside the consumer unit
Must be a new thing ?
Any links?
Delroy used henley blocks inside a consumer unit in one of his very early videos if you are willing to trawl through his back catalogue
There was another guy from up the North who used Henleys in a board as well , can't remember the guys name now
Thanks to everyone who responded.
Sounds like we might have justification to knock some ££ off the cost in light of paying the other sparky to put things right. Any other comments/observations greatly appreciated
Reply to Opinions of this wiring in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
