Discuss Outdoor lighting install in the Lighting Forum area at ElectriciansForums.net
Hi everyone, first post and novice DIY currently installing outdoor lamps. Had new extension built, builders have left twin and earth cables taped off at the ends. All except in one position where it's looped back into the wall (see pic). Directly behind the wall on the inside is the three way switch for all exterior lights. Am I missing something here? If I cut the twin and earth, which end do I connect, and do I put other end in terminal block to make safe? Confused. Any guidance gratefully received. I've installed all other external lamps and all fine. IMG_20190930_142003.jpg
It's most likely that they left a loop and just carried the cable on to the next light fitting.
If this is the case then you would need to cut it and connect both ends to the light fitting.
It's also possible that they just pushed the cut end of the cable back into the wall to protect it/keep it neat. So you need to confirm which it is before proceeding.
If it’s is indeed just a unbroken loop then it’s a straight cut and join , or is one end poke back in the hole ?
If it's a loop do as DD says, as a Caveat ensure that any joints that you make are contained in a suitably IP rated enclosure, and the joints are accessible for maintenance purposes. If it's and end of a cable isolate remove the unwanted piece of cable and terminate the other end of the cable the same as f it were a loop, for further usage.
As above then it sounds like a case of cutting it and using those to wire the light up in series?
(I'm not a sparky but I'm picking up this stuff just from reading the threads!! So listen to them not me! :) )
I tried pulling the cable out from both ends just in case it was recessed. There was a bit of play but no end of a cable found.
You need a bit more investigation Steeveecee, try and trace where the cable goes before you discard it, other wise you could compound the issue.
and where it come from. seriously, might be best to contact a Glaswegian spark. think there's a few Scots on the forum. some of them even speak English. :p :p :p
Yes you've got the general idea right but to be technically correct they would be connected in parallel rather than series.
Reply to Outdoor lighting install in the Lighting Forum area at ElectriciansForums.net
Hi all, What is the most popular outdoor wall or spike lights you install? What manufacturers? Typically use Knightsbridge's outdoor range but...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi there I am getting someone in to change an outdoor switch and outdoor wall light (like for like). The old switch and light was covered by a...
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
