Discuss Outdoor security light in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi
I'm just getting myself verified with Elecsa and I'm wiring my 1st job..Just come across a little sticking point!!
Do I wire an outdoor security light off my lighting circuit or do I take it from a FCU spurred off the power circuit?
The only reason I ask is that I always see security lights on spurs, could this be because they were added later?
Cheers
you can do it either way to comply with regs. however, i always ( if possible) feed from a 2 pole FCU. then if there's a fault on the outside ( maybe by water ingress) it can easily be isolated by the client, thus allowing RCD/MCB to be reset.
If it's a higher power light, such as a 500W flood taking just over 2A, then you might put it on the power circuit rather than overloading the lighting circuit. You need to check what the existing loading on the circuit is and choose accordingly.
If you can do it that would be a better way, think about how you can run the cables, which certificate you need to issue etc.
Is the mains up to standard ? have you got enough money in the job etc
Martin
Reply to Outdoor security light in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
I've just changed the bulb in an outdoor PIR security floodlight (to LED). But the light stays on by default, and turns off when I go outside. I...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
