Discuss Outdoor socket to internal switch in the UK Electrical Forum area at ElectriciansForums.net
Matt W
Hi folks,
I wonder if someone could enlighten me as to whether or not I could install an outdoor double RCD socket and wire it to a a pre existing internal switch?
The switch itself would have been intended to be connected to an outdoor PIR and its in a new build house. The switch is wired with 3 core and earth in brown, grey, black and earth. However I don’t need or want an outdoor PIR and would much rather have the double socket to run power outside.
The rear of the switch has the connection points of COM, L1 & L2.
The RCD double socket has connection terminals for live, neutral and 2 earth connections.
Any help or insight would be greatly appreciated,
sounds liek e 's tryint ot feed an outside socket from a lighting circuit.
Hi folks,
No, not a very good move trying to run a 13Amp from a 6 Amp lighting circuit, best move would be contact a competent Electrician to do this work for you.
question number 1: is it a lighting circuit you have there already or is it an fcu of a ring/20 rad
question number 2: is the circuit already on a rcd, if so why are you putting a rcd protected socket in?
if you are unsure on these question then you need to ring a qualified sparkie.
Ring Final Circuit Tin Hat on, flak jacket secured Cobham Armour safely mounted SAS informed to mount a rescue Opp
it'sOK pete. i have lindenmanns ready to deliver a case of rijoka.jus pm me your bank details and pin.
Reply to Outdoor socket to internal switch in the UK Electrical Forum area at ElectriciansForums.net
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Hi guys, long time lurker first time poster. I have an SWA 3 core armoured cable buried that runs to my back garden. This originally serviced an...
