Discuss Outdoor socket in the UK Electrical Forum area at ElectriciansForums.net
If I install an outdoor socket does it have to be notified to the local authority and can I test it with a multimeter with out opening the cu ?
All depends on the installation method mate.
If it's a new circuit then you have to notify it.
If you are extending it then no.
The circuit will have to be RCD protected.
You beat me to it @ruston
When Part P was conjured up,the authors must have assumed that everyone installing domestic equipment (even the householders) that they were in possession of the correct testing equipment :)
they wouldn't know a MFT if it bit their arse,
That depends on what you want to test?
If the multimeter is suitably rated for testing live mains then it could be used to measure the voltage at the socket,bjt that's about it.
could also do his continuity.
Reply to Outdoor socket in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Im just curious as to peoples thoughts on the following install I seen on a video from an Electrical firm today and they did the following: Ran...
Hi, I'm going to be installing an outdoor socket, have no problem with the outdoor/socket side, but when bringing the internal end or the SWA...
I found a 13A FCU, connected to the kitchen ring supplying an outdoor junction box, providing two SWA 2.5mm radials. Unconventional? yes. One...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
