Discuss Outdoor twin light switch wiring in the DIY Electrical Advice area at ElectriciansForums.net
Chogg001
Hi,
Apologies for lack of knowledge but here goes.
I have an outside supply that goes to a twin switch operating a light and a water feature.
I had to change the conduit position and the old switch which was damaged - now nothing works.
I put a new front on the switch but am confused as to where the ‘loose’ wire going up towards the earth actually goes.
I have tried it in all the connections but no luck.
although the wire is brown taped it does appear to be earth underneath. mains tester indicates the whole thing is live.
Grateful for any advice.
the photo is from the original switch.Outdoor twin light switch wiring E4509E94-7D24-4E8D-B64A-F1EDF6CD7953 - EletriciansForums.net
If it has been taped brown it is not likely an earth anymore. Can you show a wider but still clear picture.
Reactions: DPG
Hi, thank you for replying. I took this to give a better view. The ‘ brown ‘ wire was just pointing upwards. It may have become dislodged when the conduit was pulled apart.
  • Outdoor twin light switch wiring FFC392BF-A763-41FA-8C93-957183E38733 - EletriciansForums.net
  • Outdoor twin light switch wiring 9A1BFA96-4F5B-431D-A494-5E8AE0AC4DE2 - EletriciansForums.net
  • Outdoor twin light switch wiring 2C2A3D2B-BA29-4C80-961B-4A6C27CF0439 - EletriciansForums.net
Reply to Outdoor twin light switch wiring in the DIY Electrical Advice area at ElectriciansForums.net
