Discuss outside light tripping rcbo in the UK Electrical Forum area at ElectriciansForums.net
Megger lighting circuit. L-e short found cable its the switch wire for outside light.
Opened fitting no water present.
Disconnected fitting it clears. The cable is not shorting to the plate or any kind of pressure fault
If i disconnect light it clears.
Its a bulkhead fitting with 2 8w florescent lamps.
With power on and switch off circuit is fine. Turn switch on it trips.
Help please
L-E Fault?
What type of cable is going to the unit and is it exposed to the elements in any way?
Are there any signs that could indicate that the cable is damaged within the concealed part of the sheath that only creates the fault when bent into the connector block? (disconnection takes away strain imitating a fault free cable?
Where are you running the test from?
I find it hard to believe that just a standard bulkhead unit could be the cause of this issue when the cable connections are so basic?
Is this a fault you have been called to rectify or a unit you have installed that is causing issues?
I presume the cpc is connected in the correct place at the unit? :thumbsup
:thumbsup
Running ir test from cu. a fault to rectify getting lights back on a they didnt know what was causing it. I will further investigate when its not so heavy rain ive disconnect it just now
so's his client.
- - - Updated - - -
so's his client.
Reply to outside light tripping rcbo in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
So was on a call out today and cooker circuit kept tripping the RCD. Disconnected at the board and at the cooker switch and IR’d the cable and...
