Discuss outside light tripping in the UK Electrical Forum area at ElectriciansForums.net
B
bigbro
Hi all, advice please....
I have fitted an outside sensor light.( Domestic.) it is less than one meter to the consumer unit. i have used 1.5 twin plus e from the back of the light connected to a five amp fused switched spur socket with a neon indicator then 1.5 again direct into the consumer unit on its own 6 amp mcb. i have connected it to the non rcd side and the rcd side ensuring that the neutral is connected to the correct neutral side.... but it still trips the rcd.
Any advice please.
Brendan
you say you've connected to the non RCD side and the RCD side. can't be to both. it's either 1 or the other.
Also if the light is running from its own 6A MCB why have you fused it down to 5A, unless the manufacturers instructions stipulated this? I think you need to dig out your 2330 notes and have a look...
Ok so by using a switched fused spur you have achieved local isolation from the cu (one meter away?)
As above, why have you put a none rcd circuit on both neutral bars?
Thats why it's tripping, imbalance on the neutral line. Take the link out of the none rcd side and next time call an electrician.
I think the op means he has tried it on the non rcd side and then on rcd side if its tripping rcd them sounds as though he,s dropped a gooly somewhere along the line.and ended up with a crossed neutral.
not if the outside light is fixed to the building.
Good point Phil after reading the op. I wonder where he's getting his live feed from?
i get my live feed ( for the bearded dragon) from pets at home.
shouldn't you turn the neon driver around and hold the pointy end to get it to light up on the neutral?
Never tried that method hang on i'll give it a go ......back in a bit
:rofl: That would have worked on me at about 4 o'clock this afternoon. I put my fingers into a shaved socket that I thought was off and I got the full 240V + 110V to earth! I've nicknamed it the cocktail shock. I'm the first part and the the second part was the live tails I shoved my fingers in. Left hand is still tingling even now lol.
Reply to outside light tripping in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi, I have just replaced an old rewireable fuseboard with a 10way consumer unit with rcbo's fitted. The issue i have is that when i connect one of...
