Discuss Outside light trips circuit in the UK Electrical Forum area at ElectriciansForums.net
I have a exterior flood light, this circuit also is connected to my kitchen lights and 2 other outside lights. All lights work fine except the flood light. Once the flood light is turned on the breaker trips, all other lights are off and it will still trip. This is an arc fault breaker if the flood light switch is in the on position the breaker won't go back on. Once you turn the flood light switch off the breaker can be put back on.
I removed the switch and everything looks good no wires touching. I have not removed the flood light yet.
PROBABLY WATER IN THE EXTERIOR FITTING, sorry for the caps, caps lock on the blink
New house, or just a new house to you?
brand new build should have a warranty of sorts, a snagging list.
I see it’s in America, so UK new build NHBC will not apply.
It's a brand new, trust me the contractor or electrician aren't coming back. They had a falling out and this is on me to repair.
It sounds to me like you have a flood light taking on water
Reply to Outside light trips circuit in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
A
the situation is this: 8 x 24v rgbw flood lights for a garden, each fitting has power consumption of 45w. 3 lights into a 200w driver, another 3...
