Discuss outside lighting . cable types?? in the Australia area at ElectriciansForums.net
brs73
i've just installed some pir controlled lighting around the the perimeter of of a cottage.
i used 2.5 armoured.
i was wondering if there was an alternative black FP type cable that could be used that'll cut down on time spent making off ends.
it was out of reach so i never thought swa was absoulutly necessary. plastic conduit 's an option i know but quite laborious. don't think anyones using much pyro for this sort of thing anymore
i asked a wholesaler if they done 3 core 2.5 pyro a while back and they looked at me like i was weird.
just wondered what type of cables were out there that can withstand all weathers,look the part ,doesn't cost as much as FP and be be long lasting
cheers
sorry not an answer just a question. I was just on the screwfix site looking at the swa and they only seem to have 3 or 4 core. I would have thought that 2 core would be available so that you could use the armour as the cpc - what did you use/do?
fp''s bloody expensive .i was thinking of something cheaper really.
and i used 3 core. suppose you can still use the sheath but the cost difference'll be minimal.
i prefer a seperate cpc
cheers
How can use fp200? flex etc? both are not suitable for outside stuff, at least not for distance wiring. Why not just wire a loop 3-core pvc in loft area and branch out direct into fitting, if 3-core you have 2 switch wire options? Most can be wired direct -on or pir, or other side or time-clock, or light sensor. Or if a a large house with many permitations use 2 x 3-core loop pvc, very cheap very easy very normal?
btw, I assume by making ends off you have a trench around the house with swa burried..It would not happen in my house, is all cable visible? If so then you have customer whom is easy to please.
Why use 2.5swa? is lighting 6 x 500watt sunfloods?
I aint surprised if the wholeseller gave you a blank look regards micc/pyro. The cost would be much more, making off ends would be more tricky.
The grand design team on tv are also far from savvy, where a guy wired his house in pyro thinking it was 'safer'. Mistakingly thinking it was safer from fire hazards, Pyro is designed to still work under fire conditions not prevent fire. Pyro will get very very hot under fault condition, more so than pvc. Nothing wrong with using pyro, it will last forever, but it is not a fire provention system, rather it is used because it will still operate under fire condiditions, ie fire sirens, emergency lights, emergency power for lifts etc
cheers
can you not use tuf wire?(also called power tuf and various other things)
Hi
Pyro (MICC) is still widely used and favours most environments and looks the best. for outside installations you have few options, SWA (does not look that good very industrial looking) steel conduit, ok (but not plastic on outside does not look good in a couple of years starts to sag and misshape). pyro (MICC) looks Ok but requires some one with experience as most sparks have not terminated pyro before especially in the domestic market. As some one has already said can you run internally, you can use a lot more cable types then short flex to fitting (your connection and change of cable types need to be accessible though).
Regards
Whats wattsup on about of course fp is ok for outside use flex a no no, but also our wholesaler does sell 3core and earth we buy regular.
Seconded. Hi-Tuff as TLC calls it is superb. PVC shroud around another PVC shroud around sleeved conductors. It's a bit of a pain to work out how to terminate it but once you've sussed it it's great. Much simpler than SWA, tougher than T&E (and rated for external use), and simpler than conduit. Expensive though.
How do you terminate it?
Do you use the applicable stuffing glands?
My understanding was that grey t/e was a no no because it lacks UV protection and so will become brittle over the years if exposed to sunlight. Rubber is the same. Black pvc is uv stabilised and so overcomes this issue. Hituf is sheathed in black pvc (so too is the satellite cable attached to the outside of our homes). If the cable is out of reach and so not subject to mechanical damage, why use hituf and not standard black pvc/pvc? It's weather resistant and UV stable.
agree hituf is a bit ott,but I was wondering what exactly standard black pvc/pvc is? Does t&e come in black now?
Reply to outside lighting . cable types?? in the Australia area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
