Discuss Outside lighting query in the UK Electrical Forum area at ElectriciansForums.net
Planning on doing some outside lighting, armoured around the perimeter of garden, glanded into adaptable boxes, then conduit mounted up fence posts finishing in end boxes. Then was planning to fit downward facing lights (up-downs without up) to the face of the conduit end boxes. Was wondering if anyone had done something similar or if anyone had any advice on easier/better ways of doing it. Had also told the customer that fitting the lights they want would just shine down onto the conduit but it’s what they want so be it. Any help or ideas would be great.
Hi tuff if clipped to a wall or fence, visible… SWA if buried in the ground.
If there’s no way to hide the cable, so the lights will just have to shine on the conduit.
Reply to Outside lighting query in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi all, how easy is it to be able to shorten the drop tube of a semi flush light fitting ? Essentially what tools would I need for cutting the...
