paulhis777
- Reaction score
- 1
Discuss outside lights and sockets in the UK Electrical Forum area at ElectriciansForums.net
the new garage CU is going at rear of house inside around 4M away told to use 16mm cable to the garage unit which will be inside of house
as i say i was going to all the work myself but no more as new reg have come into force but i`m bored hanging around so i would be more than happy to do all the work needed then happily wait for a electrician to call fit new CU and garage CU then hopefully test (
(i`m more than competent to fit sockets and the lights )
but i understand that this electrician would need to access my work most important
the ground tee`s to join all the lights
as for the garage CU best to buy a unit which has RCBO`S or keep to the RCD`S ?
just want to buy these items fit to wall then plod on to the other jobs at hand
can you recommend waterproof tee`s as i`ll daisy chain the lights ?
PS sister is no longer using the token meter but is still connected
Just had quick look at your uploaded photos seems like you got 16mm meter tails going to consumer unit with 100A BS 1361 type 2 fuse?100w led flood is about the same as a 1000w halogen,,,is it a garden or a runway
And don’t get me started on that consumer unit ??Just had quick look at your uploaded photos seems like you got 16mm meter tails going to consumer unit with 100A BS 1361 type 2 fuse?
Reply to outside lights and sockets in the UK Electrical Forum area at ElectriciansForums.net
