E
eckersecker
Asked to look at some outside lights. A brick built house with a old fashioned lantern style light outside front door. Cable comes through wall into base of lamp from switch inside. Owner wants another light of same type about 5m further along wall.
Has to switch on with current light. No disturbance to walls floors etc inside. Doesn't mind cable on outside. Whats the best way to do it? I thought 1.5 SWA terminated in conduit boxes with lids with short flex to go under lip of light bases. This is the weak part of my idea as these lamps have two nuts that hold the light part of the lamp onto the base plate that is screwed to the wall. They have no depth to put in a compression gland.
