Discuss Outside lights with manual override in the UK Electrical Forum area at ElectriciansForums.net
Hi, looking at wiring some outside lights with PIR and manual override, what options do I have? As to the manual override can I have one switch for either sensor or perm on, or can I have sensor or off, has anyone got any drawings and are there any others ways thanks
If you supply a flood with PIR that has an override function then you’ll have a switch to supply and follow the instructions i.e turn on and off twice within 1 second keeps light on for 8 hours, turn off to cancel and reset. JCC do a 15 watt that has that function.
Timeguard LED PRO range have a remote fob (with battery) that overrides the PIR, it can be wired into a switch aswell. Needs to be a 1g switch thou or it has interference issues ! Saves having to run a separate live feed for manual override.
Nice system that - haven’t tried it yet but they’re onto a good thing with the modular add ons.
Don't see the appeal personally - sure the new fittings look a bit better but its a floodlight (so who cares). On the older version (still available) you can manually override them by turning the light on and off twice, less faff than wiring a fob into a switch, less annoying than losing the fob, and cheaper.
I'd take com to PIR set PIR as required and then a switch live to light (overide) if you want lights to switch on independently use 2 switches
if you have separate PIR’s you could use a three position switch,
Com-lamp
L1-perm live
L2-PIR return
On in the down position, sensor in the up position and off in the mid position
Can someone tell me function of 2 Way Switch I’ve done it so load is from cell rather than straight front switches
Electric infrared induction lamp, the induction lamp can be installed in the corridor, corridor and public places, to achieve people to the light, people from the light off, the static power consumption is less than 0.2w, the induction distance is 8 meters, the maximum induction Angle can reach 360 degrees.:p
Reply to Outside lights with manual override in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I am looking at specifying a Triac dimmer switch after a PIR and manual override to control several lights, i dont see an issue why...
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
I am looking for the connector for this rotary position sensor. The sensor is originally normally used for an EZ-GO golf cart as the throttle...
