Discuss Outside power - shallow depth in the UK Electrical Forum area at ElectriciansForums.net
So today's job was going to be to run power to the shed. Dig down a couple of foot, line with sand, lay SWA, bury in sand, add topsoil, lay warning tape, rest of top soil, job done.
The actual list of events turned out to be "Dig down half a foot, hit solid chalk, swear a bit, dig the rest of the run to make sure, bugger there's only 20cm of topsoil at the best point, attack it with the pick for a bit, **** this, it's my week off, I'm going down the pub."
I'm now deciding on the best course of action. The trench is across the middle of a lawn that shouldn't be disturbed in the foreseeable future, but I'm still not happy with just laying SWA at 20cm or so. I'm also really not too enthralled about getting down to a couple of foot with a pickaxe across the whole run.
At the moment I'm tempted to make sure the whole lot is at least 1 foot deep, lay PVC conduit, concrete it in place then run T&E. I'm pretty confident that counts as at least equivalent mechanical protection compared to SWA. (Or at least, good luck getting a spade through it!)
Would that be a reasonable thing to do, and if not has anyone got any better ideas?
You would want a mechanical digger for solid chalk and it will still take ages.
Your method with warning tape would be OK, but T&E down PVC conduit? not the easiest or nicest, I would tend to go for H07RNF flex down ducting.
Alternatively you could use cable protection cover boards or strip over the SWA.
Hire a mini trencher or at least a handheld one.
I've heard mixed reviews about whether such a handheld trencher would go through solid chalk. Unfortunately the only access to the garden is through the house negotiating a reasonably tight bend, so a mini trencher / any type of heavy machinery isn't possible.
H07RNF flex down ducting is probably a better option. I'll likely go with that. (Never heard of that flex before.)
If you’re going to dig down to 1 foot to lay in ducting, concrete and T&E, will that be cheaper than digging down 1 foot and laying in SWA?
Not at all. It's not a cost thing, I'm just not desperately happy about having SWA buried quite that shallow.
If you can get down to 200mm, get some twin walled ducting to run your swa in, cover it with plastic
aHR0cHM6Ly93d3cuZXRzY2FibGVjb21wb25lbnRzLmNvbS9tZWRpYS9jYXRhbG9nL3Byb2R1Y3QvcC9sL3BsYXN0aWMtY2FibGUtdGlsZXMtY2F1dGlvbi1lbGVjdHJpYy1jYWJsZS1iZWxvd180LmpwZw==
still leave you with 140mm plus of top soil so the grass will grow. Just don't spike the grass in the summer. Better still, gets some artificial grass, so you won't have to.
Thanks all for the replies. Eventually just decided to lob the T&E over the neighbour's fence for the first half of the run, then bury it directly in the ground by an inch or so, so I can get to it easily again if needed by just pulling it up. I've attached a little paper note to one side of the fence explaining where it is so everyone else knows to avoid it in future.
Just kidding. Used the twinwall duct & put SWA in (considered H07RNF, but eventually just thought sod it, I'll get the tough stuff.) Couldn't quite get down to 200mm for all of the run, so concreted that in place just to be sure, then laid tape. Took a while, but I'm happy enough with the end result.
Reply to Outside power - shallow depth in the UK Electrical Forum area at ElectriciansForums.net
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
We are replacing the flooring for the whole ground floor - it is a circa-2000-build house with concrete slab. We're taking the opportunity to put...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
Am I on the right lines, I ask? I've just recently moved into this house which is nicely equipped with a large 15 circuit CU unit with a split...
Hi all, I'm new to the forum so I'll give a background first. I've been a mechanical engineer for years, qualified to HND level so numerous...
