Discuss Oven grill in the UK Electrical Forum area at ElectriciansForums.net
If it trips during the action of switching off, perhaps there is an issue with the switch. Some of these switches with multiple positions have plastic parts that open & close specific contacts, and the plastic can overheat/melt.
To find out, perhaps open the unit up and if nothing is obvious, start testing. I certainly wouldn't go buying random parts in the vague hope they might be the issue.
Will do sounds a good idea. Thank you
When you say it trips the "main fuse" is this an RCD (earth fault trip)?
Probably it is a switch issue (as already mentioned) since oven elements can be leaky (electrically speaking) so if the neutral disconnects first you can get enough to trip an RCD.
But testing is a better strategy than random replacements!
Reply to Oven grill in the UK Electrical Forum area at ElectriciansForums.net
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi All, Seeking some thoughts on my own Omega free standing 900mm oven. Over the past year the oven has been tripping the supplying RCBO unit. I...
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
My Neff oven is approx 10 years old and has worked normally,until about a few months ago when it has started to trip on RCD when at high...
