Discuss Oven tripping RCD in the UK Electrical Forum area at ElectriciansForums.net
Fil2spil
Evening all, the wife cleaned the oven yesterday (self clean setting) and is now tripping the RCD but only when it gets up to a higher temp. This has also occurred when using the top oven? I have conn checked the heating element (38 ohms) and the thermostat seems to work as light goes out when up to required temp. Any ideas as to what could be causing this?
Probably a low insulation resistance on an element. It may occur on top and bottom ovens as the elements are linked via the neutral connections, so there may be a fault path to earth whichever element is on. Only way to be sure is to individually insulation resistance test each element disconnected if a general test on the appliance shows a low reading.
Does the RCD trip if any other heavy loads such as an electric shower are on? If so there could be a N-E fault elsewhere on the installation.
That makes sense if the top and bottom elements are linked by neutral line, unfortunately not got an insulation tester so might have to take the hit and buy a new element (if I can get hold of one, its pretty old), bottom one probably as hardly use the top one.
Reply to Oven tripping RCD in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Seeking some thoughts on my own Omega free standing 900mm oven. Over the past year the oven has been tripping the supplying RCBO unit. I...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
My Neff oven is approx 10 years old and has worked normally,until about a few months ago when it has started to trip on RCD when at high...
