Discuss Overhead line distances in the Australia area at ElectriciansForums.net
K
KNIPEX
I m trying to find some info or a picture would be even better, of what the maximum height is for a building below over head power lines.
thanks in advance.
What type of lines ie LV or HV as said building under HV a big no no speak to your DNO. if it is LV (ABC covered)then as for the the clearance as long as it isnt touching I would have thought it was OK I have seen this laid accross roofs before. If it is open wire then it may want restringing in ABC if it is very close. Contact your DNO. If you are building near open LV wire you can contact your DNO and they will come and fit shrouding for the duration of the build FOC.
Reply to Overhead line distances in the Australia area at ElectriciansForums.net
I have an outbuilding a fair distance from the house. In this outbuilding I just want to have some lights, a small music radio/clock, and a...
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
So earlier this year I obtained a large machine with a couple of 3 phase motors in it, and the rest single phase. I bought a VFD, correctly wired...
