Hi,
I've been asked to provide an override switch remotely for some external lighting which is on a din rail Timer so they would like to if required, to turn lights off if Timer is in operation and vice versa turn lights on if Timer is off. Would a 3 position switch like this do the trick and negate the need for a relay? 20 Amp SP 2 Way and Off Grid Switch - https://www.tlc-direct.co.uk/Products/MKK4899.html There will be 3c from the Timer to switch and 3c from switch to lights.
Thanks and any other suggestions welcome.
